Page 2 of 10
Re: Busted Rubber - The Unwanted Child- Build
Posted: Wed May 28, 2014 12:19 pm
by Customize IT
Posted: Thu May 29, 2014 2:02 pm
by Customize IT
The wheel is offset to one side for the drive. The whole swingarm was offset 1/2 to that side.
I was able to find at the breakers a longer 17mm axle for the rear. Now I can just make a longer spacer for brake side and have straight frame rails to the rear axle plates.
It cost me 3$ for axle have no idea what it is off. I may be able to use the old rear axle for the front girder too?
Notice string on the right shows the difference. Moving both plates over 1/2in means the one on the right has to move out 1in to be same distance from center.
1.5 longer can be made to proper length with just spacers.
May be able to bend some rails now I think?
Posted: Fri May 30, 2014 10:39 am
by Customize IT
The swingarm axle plates were cast steel. At least they tested that way with the spark test. Instead off taking a chance with the cast material I decided to just remake with steel.
I need to adjust from the rear with how this frame will be so they a almost perfect just need to be the right material.
This angle was the exact same thickness. Cut the back plates from it.
Fly cut square.
Milled slot it has better tolerance than stock plates.
Milled the bolt adjuster stop.
Cut to shape.
Welded and ground
Showing the bushing pressed in my jig for smaller axle.
Plates
Alighnment
Maybe next week with frame rails?
Posted: Mon Jun 02, 2014 11:34 pm
by Customize IT
Posted: Tue Jun 03, 2014 10:05 am
by Customize IT
Posted: Tue Jun 03, 2014 11:00 pm
by Customize IT
Posted: Wed Jun 04, 2014 10:29 am
by Customize IT
Posted: Wed Jun 04, 2014 11:45 pm
by Customize IT
Posted: Thu Jun 05, 2014 12:33 pm
Good progress, the back wheel looks big in the mockup. Strong frame.
Posted: Thu Jun 05, 2014 3:02 pm
by Customize IT
hansgoudzwaard wrote:Good progress, the back wheel looks big in the mockup. Strong frame.
Posted: Thu Jun 05, 2014 11:04 pm
by Customize IT
Posted: Fri Jun 06, 2014 7:37 am
I have to admit...wasn't a big Fan of the way lower Rails left so much Motor exposed, but I'm really starting to dig it.Extremely different.Definately a cool Build Dude.
Posted: Fri Jun 06, 2014 12:18 pm
I take it back. That looks just right.
Posted: Fri Jun 06, 2014 1:45 pm
by Customize IT
Thanks! Friends!
Posted: Sat Jun 07, 2014 5:09 am
by gearhead1951
