Page 6 of 8
Posted: Fri Mar 11, 2022 11:17 am
One of the things I realized after the fact was that the chain is likely to hit the shifter. I made a little guide for the chain to run in & keep it up & away from the shifter. While doing some adjustments to the linkage for the shifter, it seems that its a little tight. I dont know whether the linkage is at to much of an angle or what. Ill be working that out over the weekend.
- IMG_0033.jpg (68.76 KiB) Viewed 8466 times
- IMG_0032.jpg (65.96 KiB) Viewed 8466 times
Posted: Fri Mar 11, 2022 1:36 pm
Posted: Thu Mar 17, 2022 8:44 pm
Turns out a couple heim joints in the linkage were bad. Replaced 2 & now shifts smooth. Heads on, the exhaust wrapped & I put the muffler on the buffer for a minute.Ill be powdering the rocker covers & working on a mount to secure the font of the pipes to the frame over the weekend.
- IMG_0025.jpg (80.12 KiB) Viewed 8458 times
Posted: Thu Mar 17, 2022 9:02 pm
looks like shes gettin close
Posted: Fri Mar 18, 2022 9:24 am
Yeah…think it’s getting close. Have no idea when my mag parts will get here. Still some odds & ends I can tighten up until then.
Posted: Fri Mar 18, 2022 9:10 pm
Posted: Tue Mar 22, 2022 3:34 am
The new powder coat has a nice brass look to it.
Posted: Tue Mar 22, 2022 9:48 pm
railroad bob wrote: ↑Tue Mar 22, 2022 3:34 am
that’s the gold/high gloss clear that I did the rims in.
Posted: Wed Mar 23, 2022 1:57 pm
Posted: Thu Apr 07, 2022 6:21 pm
by Swamprabbit1
Looks good brother
Posted: Sat May 07, 2022 8:36 pm
Posted: Sun May 08, 2022 4:00 pm
Posted: Wed Jun 01, 2022 9:31 pm
I got the valves adjusted & will do a compression test over the weekend. My dumb ass didnt think about wiring untill now & now I have to figure out making wires as invisible as possible. I made this cover that sits on top of the engine plates to hold the switches. It will also hide (for the most part) the wires.
- IMG_0019.jpg (72.38 KiB) Viewed 7874 times
Posted: Thu Jun 02, 2022 11:08 am
by Dusty-Dave
I kinda like vintage style wire string laced and left right out there for everybody to see.
Posted: Thu Jun 02, 2022 2:44 pm
That looks clean. Mainly the cover will be to hide the fuses. Some of the wires will be visible but hopefully discreet.
