After reading and rereading the rules book I finally decided this spring that a Bonneville effort would be a good way to spend the next few years of My retirement. After much discussion I am maybe positive that I want to build an AVBF A being a special construction frame which will allow me to get the head stock as low as possible with the 16" rims I chose. The rules allow as small as 15" rims but the cost and availability of tires and rims and the fact that I had a new w speed rated 16" tire made me settle on 16 inches. V is vintage engine produced before 1956 with a 33.33% size advantage given to flatheads. B is blown and F is fuel. Right now the plan is to run Nitrous oxide and alcohol through fogers because of a flatheads notoriously poor breathing even if blown. I started looking for parts this spring Got a pair of 16" 250 Ninga rims and fork and today I won a set of 37 Sport Scout cases. So it will be a 1937 Sport Scout.
Still haven't picked a displacement a 45" stock displacement Scout would run in 500 cc the ABVF record is 73.903 but the 500 cc AVF record is 111.839 so the blown speed should go way up soon and a 57" stroker would run in 650 No record for ABVF but AVF is 144.531. Leaving it a 45 would give me lots more room for piston squirters but would require a pair of std. bore cylinders but I just prefer 57 inchers and the cylinders could be way oversize per the rules.
Main thing I need to find next is a pair of cylinders I would really like to buy new ones but the rules require original cases and cylinders or exact reproductions and only ones I can find so far say improved ports and the rules committee says not no but hell no. I hear that there are exact repros but can’t find anyone selling one that will offer any documentation and at $1500.00 to $2000.00 I sure don’t want a pair of paper weights.
I’ve been promising to start writing this up for a while but having the cases and being able to assign a year to the build finally got me moving. Stay tuned
[/url][/img]
[/url][/img]
[/URL][/img]
