Ive been hunting down early frame rakes , trying to get correct rake for 1926 scout.
Ive measured 22 - 23 degrees but need to be bang on , they use these frames in the wall of death ,because of the geometry and I dont want to stuff it.
Frames bent to start with . ffs!!
the servicar from seat post forward is the same as 45 solo , the rake = 23 degrees , still trying to find JD rake .
seems to be typical rake in the 1920 - 30s
WLA = 23 degree
*short 36 - 40 BT = 28 degree
*medium 41 - 45 = 29 degree
*long 46 - 47 = 30 degree
48 - 64 = 30 degree
65 - 84 = 30 degree
^^ * Bruce Palmer numbers above
37 - 40 = 25 degree
41 - 46 = 28 degree
46 - 47 = 30 degree
Id say this guys figures are accurate
http://www.raceframe.com.au/
HD catalog brochure 2005
rake and trail...
fxst = 32 / 5"
flst = 32 / 5.8"
flht = 26 / 6.2"
fxd = 28 / 4.1"
fxdl = 32 / 5.1"
fxdwg = 32 / 5.1"
v rod = 34 / 3.9"
xl = 29.6 / 4.6"
xlc = 30.1 / 4.7"
45 HD frame dimensions
Re: 45 HD frame dimensions
- wla resizedimage.jpg (209.05 KiB) Viewed 8061 times
this archive site has 1000s of military tech manuals for trucks , tanks , bikes etc
https://archive.org/stream/Tm9-879HarleyWla
