1969 T120r Triumph Hardtail Frame Print
Let's use this as an archive for whatever plans you have, or links to plans elsewhere. Before posting plans here, make sure you have permission to do so.
curt has checked the print says it is GOOD!
I have revised the print and radius the tubes in the Top and Front view and also made the text in the dimensions larger easier to read.
This is the CAD drawing file.
https://www.dropbox.com/s/3k0jezcg6cia9 ... 1.dwg?dl=0
This is the Full page print.
https://www.dropbox.com/s/u9jkjyqgem96i ... 9.xps?dl=0
Add these 4 together to make a large 4 pages print.
https://www.dropbox.com/s/80czr6xv4e8tp ... 1.xps?dl=0
https://www.dropbox.com/s/kulh9w7614aui ... 2.xps?dl=0
https://www.dropbox.com/s/a5u9wsn5g9wwt ... 3.xps?dl=0
https://www.dropbox.com/s/skdbidhkzzifi ... 4.xps?dl=0
Re: 1969 T120r Triumph Hardtail Frame Print
hope someone can use these id love to see some ol school chops built from this and thanks for the work converting these nate
Return to “Downloadable plans Area”
