gonna be a slow build
Okay, put my thread back in so I'll have a pickup point when I get back to it.
starting with the uncut donor axle
uncut axle.JPG (75.32 KiB) Viewed 22671 times
not the same axle but shows how much it was shortened  32 in back plate to back plate
cut axle hsg.JPG (20.37 KiB) Viewed 22671 times
cut axle bolted together for welding
axle fixture.JPG (51.3 KiB) Viewed 22671 times
electrolysis set up with laundry soda to help remove rust
Laundry Soda barrell.JPG (135.03 KiB) Viewed 22671 times
workin up the axle plates
starting axle plates.JPG (124.55 KiB) Viewed 22671 times
axles plate
axles plate
axle plate.JPG (120.88 KiB) Viewed 22671 times
Re: gonna be a slow build
and a continuation.
getting the tail frame put together
started on tail.JPG (140.16 KiB) Viewed 22670 times
made myself a purty neck fixture
neck fixture.JPG (126.14 KiB) Viewed 22670 times
getting the big chunks set in place
gittin mocked up.JPG (82.39 KiB) Viewed 22670 times
double cardan made from the cut down driveshaft
double cardan.JPG (116.45 KiB) Viewed 22670 times
fitting bottom rails
starting bottom tubes.JPG (62.99 KiB) Viewed 22670 times
bottom rails takin shape
some more
adding the top rails
top rails.JPG (136.97 KiB) Viewed 22669 times
makin the neck a bit more solid
building up the neck.JPG (121.88 KiB) Viewed 22669 times
some scraps to hold things in place
wood jig for engine mounts.JPG (118.72 KiB) Viewed 22669 times
using drill and flat file to turn down inner sleeves for motor mounts
old fashined lathing.JPG (115.36 KiB) Viewed 22669 times
engine mounts.JPG (134.44 KiB) Viewed 22669 times
the donor motor. A 350 from and old camper. 1689xx mi on broken odometer. turned out to be a crate replacement with about 5000 mi on it.
Very cool and nice work there sleepyonthree. I have also been thinking about making a trike, i have a spare turbo 350 transmission in good shape plus rear end and a 350 engine to use. Engine needs a bit of rebuild but would be cool for a kick ass trike build. Time will tell :bow-blue: :clap: :obscene-drinkingcheers:
you know, i was wondering if you were making any progress on this. get on it man, this is an awesome project!
:popcorn: :D
Thought for a minute you were building an Olds Trike with that Rocket valve cover. Good job.
Jim
jimmib wrote:Thought for a minute you were building an Olds Trike with that Rocket valve cover. Good job.
Jim
Found them in my stash while rummaging about. Strongly considering making and adapter plate to use them on the chevy motor.
That would be a cool touch!
I still love the way you cleaned up the differential, way cool...
I asked you before about your plan to remove the motor ater the frame is complete, in case you needed to swap it out.
I think you said the plan was to just take it apart while in the frame.
Have you considered pinning the top backbone so it could be removed?
railroad bob wrote:I still love the way you cleaned up the differential, way cool...
The electrolysis bath sure makes for less time in the blast cabinent and it only does the rust, good metal remains untouched.
Had considered a removable backbone, but given the easy access to the motor I went all welded. The motor I'm using for mockup is a bare unit, once the real ones in place if I pull it out its to take it apart anyhoo so mights well do it from the outset.
Whoops, to quick(spastic) on the keys. :roll:
hmmmmmmmmmmmmmmmm, very interesting...... :think: now where can I find a large V8 and autobox......? :shhh: :shifty: :snooty: :dance:
Maz wrote:hmmmmmmmmmmmmmmmm, very interesting...... :think: now where can I find a large V8 and autobox......? :shhh: :shifty: :snooty: :dance:
The Rover V8 makes for a good looking trike.
