SELF INTRODUCTION: Hi All, My name is Craig Irish. I live in Northern California. I've been a member for a long time but I am re registering because the board is new. I have a project build thread on this board call Irish's Old School Chopper Project. I'm glad the board is still going and I very much appreciate Dan keeping it going. Thanks Dan! Craig
You're done! Celebrate and go for a test ride! OK go for a test ride first...
The chain drive
Drive...
school yard bike pics 013small.jpg (101.25 KiB) Viewed 8323 times
The business side.
The business side!
Room for one more image so here you can see the bronze oil tank that I designed and my brother Grant built and engraved with my Skull Leaf Clover Irish Cycles logo. Thanks to pops David Irish who machined the vented cap and filler neck for the tank.
Skull Leaf Clover Oil Bag by Grant Irish.JPG (73.63 KiB) Viewed 8323 times
OK I finally rounded up all of the photos that I have. I'll post them in order that they were taken which will show the different looks. The only real differences are the gas and oil tanks. Later I changed some other bits also. So here goes...
This is in my driveway while I was still tuning the carburetor and ignition and sorting the clutch and linkage for the clutch.
This is June '06 with the bronze tank. I was engraved on top with my cyclhed logo, a skull with wings, no not HA! I need to find a picture. The tank is still around somewhere.
Chopper june06.JPG (64.28 KiB) Viewed 8312 times
The gas and oil tanks were made with silicon bronze sheet metal with brass caps and bungs. They had a bronze and green colored patina applied to them and then they were waxed. The gas tank looked cool, if a bit crude, but proved to be too heavy.
Chopper 2 june06.JPG (57.78 KiB) Viewed 8312 times
I switched over to the original steel sporty frisco tank because the bronze tank was too heavy and broke the mounts off the frame! I also switched back and forth between the bronze and steel oil tanks when one would spring a leak and I'd have to weld it.
I rode the bike to the 2007 Horse Smoke Out 8 in Salisbury, NC and camped for a couple days. The night before I left I painted some yellow panels on the tank. I had the tank pinstriped by a guy called Jaybird at the show. I met some cool folks and had a blast
My camp at Smoke Out 8, 2007
Jaybird and his buddies.
Jaybird striping my tanks Horse SmokeOut.JPG (45.19 KiB) Viewed 8312 times
Tank panels
Tank top pin stripes
I still have this tank on a shelf in my shop.
Riding with some friends North GA Oct. '08 "Do these chaps make my ass look missing?" (that's not me BTW)
Ride 1-13-08 North GA mountains .jpg (117.59 KiB) Viewed 8312 times
I moved from North GA to North CA in '08. The bike underwent a transformation soon thereafter....pictures coming soon. Stay tuned! Thanks for being patient and not posting here until its done! Craig
SELF INTRODUCTION: Former member of CBH....learning the ways to chop. Had a few bikes before....a few now...and lots more to come. Currently on a trike build, and a bike build. Thanks for having me back on board Dan. Hopefully I will do you guys proud!
Thanks hoser! I thought I'd better get back on here and see what's up. I'm going to keep updating this until it's complete. I'll post pictures of versions 2, 3, and 4. Or should it changed be 2.0, 3.0....
The only real changes I made were: a new fuel tank with a tunnel, it's the same style Sportster tank, but tunneled and mounted low over the top tube. A much better look IMO.
And I changed the color on the bronze oil tank to black patina from the green. I also changed the headlamp out for a Arlen Ness aluminum unit.
The new tank...
Oil tank black patina by brother Grant.
The new Ness headlamp. In the video you can see it vibrating....I had to tighten it up!
Side view...
Yes, it's running.
View from the top...
Version 3 changes were not much, but it changed the look quite a bit: Changed out the sissy bar for some hotrod style drilled struts that I whipped up, pillion removed and some bronze bits for the engine and air filter.
Left side
Right
Ass.
motor bits
No front fender...another change.
shift lever
The next change I made was to switch over to foot shift from the jockey/suicide clutch set-up. I welded a bracket onto the frame to hold the end of the clutch cable and switched the lever on the trans for a cable type. I installed a Jaybrake clutch lever to match the front brake m/c on the other side. I found a matching left side forward control too; don't ya love ebay? I installed the proper lever on the trans and connected it to the foot pedal with bent rod. From looking at the pics I also went back to the steel oil tank and also changed the tail lamp and tag bracket to a cat eye. Oh and it looks like I added some ISO pegs with stirrups...oh and the sissy bar is back!
the clutch lever...unbelievable...
linkage..amazing.
clutch cable holder...why did I take a picture of that??
dunno...
steel oil tank painted semi gloss black..ooh exciting.
new left matching forward control with bitchin' iso pegs...wow
SELF INTRODUCTION: I am a mechanical engineer working in the oil and gas industry based in a gas treatment plant in south Taranaki new Zealand. I live in New Plymouth, Taranaki, New Zealand I have been riding bikes for over 40 years
Thanks for sharing your build. I followed it on the old board. Its one of the best build logs.................inspiring.
Cheers
Clive
"This is your life, are you who you want to be?
This is your life, is it everything you dreamed that it would be
When the world was younger and you had everything to lose?"
Switchfoot
I thought I would finally finish adding the last pictures of my CBH Old School Chop. This is the final version of the motorcycle with the black paint, white flames and red striping.
