railroad bob wrote:Interesting look to it, and nicely fills the void between the frame members. Got more coming for the front?
Thanks Bob, and yes there is more coming for the front, there will also be a space under the front for the induction system and coils etc.....I've marked and cut out the main front top piece and there's a pic below of me making the aperture for the filler cap - using the original Yammy aircraft style filler.....
![mazfz750 061.jpg](./download/file.php?id=1057&sid=ff06844ec24e73be16c1124271808c48)
- mazfz750 061.jpg (134.8 KiB) Viewed 2888 times
more progress (and pics) soon......
railroad bob wrote:And, I'm noticing that the flat surfaces on your frame make it easier to join and attach members and mounts.
Or seems so to me at least. What do you think? Does this work better than round tube?
Seems coping is likely to be a little easier than on the round tube.
Yes it does make it easier to attach brackets etc but with some of the angles, coping becomes a complete nightmare and has to be done manually as there is no way of using a holesaw or anything similar to form the cutouts....like I've said before, I always do stuff the hard way
