Brazing
An area for general welding posts that don't seem to fit anywhere else.
Brazing
Iam hoping to master this method I like it had a go recently and although my set up is pretty basic just fluxed rods and a hobby sized torch and a small set of different sized nozzels I really had some fun, enjoyed it much more than using the mig, I understand you can get silicon bronze mig wire would like to give it a go... I guess you might call it old school but in the hands of the professional the end results are just amazing..
Anyway some pictures of proper brazing done By Brian of
http://www.silverstonesuperbikes.co.uk/xr69_5.html
check this out
Brian 2.jpg (29.2 KiB) Viewed 66495 times
Re: Brazing
more..
brian 3.jpg (19.03 KiB) Viewed 66494 times
Brian 4.jpg (28.23 KiB) Viewed 66494 times
neale
SELF INTRODUCTION: I have had an interest in choppers from the '70's when I was in high school, reading custom chopper mag etc, I have never had or built a chopper to date, I'm trying to learn, I am acquiring equipment (tube bender, oxy torch etc) and am trying to get started building up the skills and information I need to get started on building a chopper.
My current bike is a Yamaha XV1000, I would class it as a mild custom rather than a chopper, a lot of the useless (to me) bits have been removed and I am trying to modify and chop a few more things off to get it to a longer, lower, leaner machine with better performance (custom shortened rear shocks, refabricate forward controls and drag bars, try and get raked cups working on it etc), but IMHO it doesn't have the right type of frame to build a "proper" chopper on, so I am looking for a more suitable donor bike for the project.
Re: Brazing
Post by neale »
Nice work.
NB: It's probably just my twisted mind, but the first thing I thought when I saw the picture of the front of the headtube was all that'd need to be the back of a naked woman would be a head (or back of a head, and spray of half a dozen lines of brass there would give you a blonde head ;^)
Neale
Re: Brazing
real nice
Re: Brazing
Looks very difficult. Lots of nooks and crannies. Quality work.
Kiwicaveman
SELF INTRODUCTION: I am a mechanical engineer working in the oil and gas industry based in a gas treatment plant in south Taranaki new Zealand.
I live in New Plymouth, Taranaki, New Zealand
I have been riding bikes for over 40 years
Re: Brazing
Post by Kiwicaveman »
Those are great photos, great skill and workmanship.
The term "Brazing" is not really accurate.
Brazing is the term used to describe a filler that flows by capillary action into a very close fitting joint.
The frames above look like he have been "Braze Welded" or "Bronze Welded". These terms apply to a filler wire that joins the parts without flowing by capillary action. A few decades ago it was called Bronze Welding, the modern term is Braze Welding.
I prefer to call it Bronze Welding (I'm very old school) but this is not an accurate term as the fillers are Brass (i.e. copper and zinc with other alloying elements like silicon, nickel, silver, etc). Bronze is copper and tin with other alloying elements.
I have used Braze Welding for many years to repair and modify steel tubular bike frames, mainly dirt bikes.
I use "Castolin 16 / XFC / MF" filler wire and a light weight oxy-acetylene welding rig / torch.
Castolin 16 is rated as "AWS A5.8 RB CuZn-D" under the American Welding Society system.
Castolin 16 is alloyed with 1% silver and nickel. It fits the definition of both a brazing filler and a braze / bronzing filler as it will flow by capillary action but by reducing the heat input (temperature) it can be built up into fillets.
It has a tensile strength of 700 - 800 MPa (about 100,000psi minimum).
It is reasonably easy to use and with some practice very good results can be obtained.
Cheers
"This is your life, are you who you want to be?
This is your life, is it everything you dreamed that it would be
When the world was younger and you had everything to lose?"
Switchfoot
Re: Brazing
Met a guy in Las Vegas who used brazing to build a frame. He did a copy of a vintage BMW frame, using smaller diameter tubing
for the primary members, which were inserted into a larger tube at the junctions and then brazed at the interface of the different tubes.
His bike looked really sweet.
Re: Brazing
Anyone thinking of doing some gas work might find the chart useful. Same chart Word and Exel.
Welding Tip Size Comparison Chart.doc
(96.5 KiB) Downloaded 1465 times
welding tip size comparison chart.xls
(31 KiB) Downloaded 1308 times
devilman
SELF INTRODUCTION: Hey, how about. I'm Schulz Francisco Santiago, Chile. I am a mechanic and welder, and while working in the manufacture of live traps for almost all animals my true passion are the vehicles, automobiles and motorcycles, restoration of some and making other. I congratulate you sign up for this well of knowledge, im participate in other free information community, chatarrero rat rodders Argentina, where we arrived at interesting things about how and why. Personally I have a collection of more less interesting automobiles and motorcycles, a Mercedes Benz 250 1972 automatic in restoration , a 1967 Chevy II soon to be revived as scrap pick up, and clearly my motorcycles, a Honda CB 450 Nighthawk modified as between wars bike is my current project Is a beautifull engine. I'm making the girder fork at this time, a bobber carried Motorrad, my vehicle abitual a Maico MD 250 awaiting restoration parts for, a Yamaha Enticer waiting for a change of 350 cc engine, a BMW R-67, 1954 waiting also a part of the starting lever. Also chassis, engines, tires, and parts to make what I can think of.
I think i can help and contribute in this community.
A hug for a distance.
Re: Brazing
Post by devilman »
@Maxthegardener that is pornowelding! Wooooow!
Never argue with an idiot, low to his level and beat you by experience.
Return to “General Welding”
