How I prep tubing
How I prep tubing
I use this mainly to get Aluminum tubing ready for the buffer, but it works well to use to prep your tubing used for frames & whatnot.I like to clean up all the tubing before I work with it & this makes it easy.I had a bench top drill press laying around, so I fit it to a 6' section of stainless the same diameter as the original post.Put a live center in the table, & used a bow roller off a boat trailer cut it in half, ran a bolt through it & chucked it in the drill.Heres a pic with a length of tube chucked up.Hope someone will find this usefull.
- DCFC0001.JPG (163 KiB) Viewed 6213 times
Re: How I prep tubing
thats a real good idea ill be useing thatone and hows the bsa project comeing
Dude...I used that thing alot.I just never thought much about it....then I thought maybe someone will use this idea.Builds goin slooow...ha
amazing!....now why didn't I think of that
Hope you get the build moving along again dude
i sometimes use the lathe to clean the ends where im going to weld them but my lathe is small that would give more room
Just a note....If you go as high as mine At 6' high the base is to small.(itll be real top heavy)You'll have to make it wider.
thanks for the heads up id of crashed the dam thing
