![Clap :clap:](./images/smilies/eusa/clap.gif)
1979 Honda CB750 Bobber build
- jonester123
Re: 1979 Honda CB750 Bobber build
Another picture, with frame back in jig and bolted to motor again. Checking to see how it is all looking. ![Clap :clap:](./images/smilies/eusa/clap.gif)
- bth_100_1449_zps24ed6561 chopper build progress 1.jpg (13.59 KiB) Viewed 9216 times
- rudog
keep it up ![watching :popcorn:](./images/smilies/lurker.gif)
- jonester123
Hey rudog, hows it going been a long time. I just picked up my axle plates and one extra plate for my ram mounting bracket fabrication, already traced the axle template on plate. One plate will do both axle plates, of course had to purchase a big pack of cutting disks to cut it all out nicely. hahaha ![biggrin :D](./images/smilies/icon_e_biggrin.gif)
- bth_100_1454_zpsf60e4d6b Axle plates fabing 2.jpg (8.21 KiB) Viewed 9206 times
- jonester123
Progress today, got axle plates cut out to rough shape. Need to put them on the grinder to make nice and perfect, then drill out the axle slots. One step at a time.
- bth_100_1462_zps4957b756 Axle plates all cutt out.jpg (9.31 KiB) Viewed 9191 times
keep at it dude, I'm back again so will be keeping a watchful eye on you
![Talk to the hand :hand:](./images/smilies/eusa/hand.gif)
![Image](http://i1051.photobucket.com/albums/s421/Mazchopz/bikebanner3.jpg)
- jonester123
Thanks maz, I borrowed my neighbors tube bender, I got the lower frame rails bent up to axle plates. Twenty degree bends, soon as my air hydraulic 8 ton ram arrives then I can get it mounted on my jd2 bender and learn how to use it. Will it be strong enough to mount on my worktable now I will have the ram doing all the pressure, want to make sure of mounting it up good enough.
![Wink ;)](./images/smilies/icon/wink.gif)
- jonester123
Forgot to add picture hahaha
- bth_100_1466_zpsc7680fdd Chopper lower rails bent to axle plates.jpg (13.64 KiB) Viewed 9179 times
great news hun, nice to hear you are still at it
If you are using an air/hydraulic ram instead of a manual lever bar then you should be able to mount the bender on your table, just make sure the ram mounts are good and strong (lots of stored energy) and that they connect to the bender and not the table.....
![Dance :banana-dance:](./images/smilies/banana/dance.gif)
- jonester123
Thanks maz, I will post up a picture of the ram all fabed up on bender. using thick wall tubing for mounting ram plus half inch thick plate. I will make sure it is all welded up real good and solid. hahaha ![Wink ;)](./images/smilies/icon/wink.gif)
- jonester123
Hey guys and gals, more progress. Got seat area and wishbone fabed up and welded real good, trimmed tubing to axle plates closer to size needed. Here is a picture.
Also a picture of slow fabrication of seatpost and upper plus lower rear engine mounts.
![Dance :dance:](./images/smilies/eusa/dance.gif)
- bth_100_1486_zpse5eb5ce3 chopper uper rear engine mounts fabing.jpg (10.82 KiB) Viewed 9161 times
- bth_100_1489_zps3bf48716 Rear hardtail mockup.jpg (12.95 KiB) Viewed 9161 times
- jonester123
Hi guys and gals, my old welder broke down so I had to order a new one. I purchased eastwoods mig 135, it can be used with gas and comes with gas setup. Also can use fluxcore wire. Should arrive in about 10 days and I will post some pics of it and more progress.
You're a good example of persistence Jonester, keep it up, you'll get there.
- jonester123
Some more progress pics on the hardtail frame build.
![Whistle :whistle:](./images/smilies/eusa/whistle.gif)
- bth_100_1589_zps30c4ad1c Axle plates fabed in place2.jpg (15.02 KiB) Viewed 8842 times
- bth_100_1588_zpsc8506562 Axle plates fabed in place1.jpg (13.84 KiB) Viewed 8842 times
hang in there, man. we're all still here rootin' for ya and waiting to see that fire-up video, as well as the crap-eatin' grin on yer face after you take it for a spin.
