SELF INTRODUCTION: Hi Dan, thanks for your time and energy spent on this new board. I hope you will give me a waiver on the email account, I have used gmail so long I don't have a clue what my service provider account is. I just returned home from a 2 week trip in New Mexico, have a few good pix, can't wait to share my off-highway traveling. Got to put 1400 miles on the scoot.
Hey guys and gals, more progress. Setting up hardtail for welding, got lower axle plates welded in lower frame rails and prepairing the top tube of hardtail for axle plate upper welding. Also got lower frame rail spacer fabed and ready to weld in place, working on the seatpost down tube and lower spacer tube for welding in place. Slow and steady, trying to not have anything twist out of shape while welding. Going to mount front new tire on rim, it has been waiting forever hahaha
bth_100_1666_zps61b869ad Chopper mockup of hardtail build.jpg (12.8 KiB) Viewed 9075 times
bth_100_1667_zpsde494fdfAnother hardtail mockup 2.jpg (14.29 KiB) Viewed 9075 times
Hi Railroadbob, I fabed the bracing so they came lower underneath backbone. Hope to clear enough space for custom built gas tank, I guess time will tell.
Finally more progress on my build, got hardtail almost all done. Axle plates all welded in place, working on the seatpost and lower frame rail spacer tube coping. Then get it all tack welded in place.
100_1742_zps9598263b Chopper axle plates all welded in place.jpg (247.74 KiB) Viewed 8969 times
100_1738_zps5ed6d3d1 Chopper mockup with rear tire and fender mocked up.jpg (252.75 KiB) Viewed 8969 times
SELF INTRODUCTION: I was on the old forum, I have more tools and more projects now, I have a wide range of projects , home built boats, a few buggies, snowmachines and a few snowhawks, latly I have been collecting old broken machines most recently a marvel roll in bandsaw, and a old lathe that needs some love from 1908, and about 10 bike projects, most were not running when i got them , same with my mill and bandsaw I had to get them operable. Looking to further my knowledge and share what i can offer..
Is there a particular reason you put the Braces back on the Backbone to the Legs?It looked much better without.Have you given any Thought to redesigning the Gusset so you wouldn't need them?But if the Tank will hide them guess it doesn't matter.....You disappeared for awhile Dude.....glad you're back on the Build.
Hey Jeff L, I did the bracing the same as Honda had the frame. I need in between to mount my dual coil system for engine, if I did big gusset in between then no room for coils. Still learning and designing as I go along, not quitting on the build just been busy with life stuff.
