Which Bender to build
Norton
SELF INTRODUCTION: Industrial Designer/Tinkerer, I enjoy building Beer brewing racks, lighting, seating, handrail systems, rebuilding antique ride lawn mowers, basically anything involving metal, wood or concrete. I have several years of experience with 3D modeling and sheet metal l layout gained while working at a metal fabrication firm in Northern California.
Post by Norton »
I'm trying to decide which of the two tube benders posted on the main page that I should build. The original JD2 model or the CBH model. Is there an appreciable capability difference between the two? I noticed that the JD2 unit drawing specifies that it is set up for 4.5" CLR dies, but can it use other radius dies?
Re: Which Bender to build
http://www.choppercompendium.com/ccforu ... ender+dies
There is more at TOOLS AND EQUIPMENT" , all pretty much to help you decide.
Check out the one MAZ built.
Yeah , and her "bend it on the diamond " square tubing die !
Norton
Post by Norton »
Thanks I will read all that.
Norton
Post by Norton »
ok that hydraulic "monster" looks like the ticket. Are there plans available for that machine?
Re:MechWerks
http://www.mechwerks.com/Mechwerks_plans_drawings.htm
Scroll to the bottom of the page.
This gent (Steve) has been around a long time.
dirtbag
SELF INTRODUCTION: I was on the old forum, I have more tools and more projects now, I have a wide range of projects , home built boats, a few buggies, snowmachines and a few snowhawks, latly I have been collecting old broken machines most recently a marvel roll in bandsaw, and a old lathe that needs some love from 1908, and about 10 bike projects, most were not running when i got them , same with my mill and bandsaw I had to get them operable. Looking to further my knowledge and share what i can offer..
Post by dirtbag »
Thats the style I built, a bit different but same style, i dont have a decent pic so i wasent going to comment, I like it as the tube stays level and I use a magnetic angle finder. The only thing is it only does a 90 or a bit more, mine has a big base and is portable yet very stable..I am kind of thinking of building another one of a different style just for fun and makeing my own die on the lathe..the first one I bought the dies from pro tools
dirtbag
Post by dirtbag »
I have a horizontal bender at present.
It works O.K.
I think this one looks interesting. Seems very compact, & I probably would not be bending past 90*
MechWerks
MechWerks
Can not beat my air operated hyd pump driven bender but i got it in a hell of a deal!
I got a manual I will never use JD2 no dies? where you at?
