![biggrin :D](./images/smilies/icon_e_biggrin.gif)
1979 Honda cb750
- jonester123
1979 Honda cb750
Hey guys and gals, I am trying to remove my trees from bike. There is a nut on top to undo, first time removing trees. I need them off upper and lower for my springer to mount up, any help greatly appreciated. I can take picture if needed. ![biggrin :D](./images/smilies/icon_e_biggrin.gif)
- jonester123
Re: 1979 Honda cb750
Here is a pic of trees I need removed for springer front end.
- 100_1779_zps122df859 Trees removal.jpg (229.91 KiB) Viewed 8409 times
Just unscrew the Nut & the top Tree should pull off.Might be another Nut, undo that & the bottom Tree will fall out of the Neck.You'll have a Washer or 2,Dust Caps & Bearings top & bottom,(mine are Ball Bearings so be carefull when taking it apart).the Races will be press fit in the neck.Go through the Neck with a long Punch & tap the bottom of the Race if you need to remove them.
- jonester123
Thanks Jeff, got it all apart now. Doing mockup of springer front end.
![Biker :auto-biker:](./images/smilies/auto/biker.gif)
![Clap :clap:](./images/smilies/eusa/clap.gif)
- jonester123
Trying to remove lower tree from steering shaft, no nut to take off. Looks to be press fitted inside tree, want to use steering shaft for springer front end. ![biggrin :D](./images/smilies/icon_e_biggrin.gif)
- 100_1788_zpsd959b876 steering stem.jpg (144.78 KiB) Viewed 8389 times
This is how I have seen it done cut out then welded it to the tree lower tree. Or turn it like him
![Image](http://i850.photobucket.com/albums/ab65/hoggy5/DSCF0710.jpg)
![Image](http://i850.photobucket.com/albums/ab65/hoggy5/DSCF0711.jpg)
![Image](http://i850.photobucket.com/albums/ab65/hoggy5/DSCF0713.jpg)
![Image](http://i850.photobucket.com/albums/ab65/hoggy5/DSCF0714.jpg)
![Image](http://i850.photobucket.com/albums/ab65/hoggy5/DSCF0720.jpg)
![Image](http://i850.photobucket.com/albums/ab65/hoggy5/DSCF0725.jpg)
![Image](http://i850.photobucket.com/albums/ab65/hoggy5/DSCF0747.jpg)
![Image](http://i850.photobucket.com/albums/ab65/hoggy5/DSCF0750.jpg)
![Image](http://i850.photobucket.com/albums/ab65/hoggy5/DSCF0767.jpg)
![Image](http://i850.photobucket.com/albums/ab65/hoggy5/DSCF0773.jpg)
There are a few on E-Bay for cheap.You could always sell your complete Frontend for a little Parts Money.
- jonester123
Thanks guys, already cut out the lower tree from stem. ![biggrin :D](./images/smilies/icon_e_biggrin.gif)
- 100_1789_zps4aff79ee springer front end steering stem fab.jpg (188.03 KiB) Viewed 8371 times
