Welder Cart build
Welder Cart build
Hey guys and gals, making a nice welder cart for my new eastwood mig 135amp welder. 2ft wide and 3ft long. Made extra space for big gas bottle, I got some big tires to use on it. Want to make sure it can roll all over property with ease. Coming along great, awesome practice to dial in new welder. hahaha :D :obscene-drinkingcheers:
bth_100_1627_zps04ddd9f1 Welder cart fab 2.jpg (12.04 KiB) Viewed 15929 times
Re: Welder Cart build
Good thinking there Jonester, practicing on something you'll be using.
Hello Railroad bob, hope all is well with your projects. Got working on welder cart build today, finished fabing and welding up the whole frame. Got three coats primer and two coats blue so far, Fabing up wheel mounting brackets 4 of them to weld on frame, then make some holders and shelving stuff. :D
100_1800_zps7ca12d8d welder cart painted.jpg (226.09 KiB) Viewed 15798 times
Progress today, got 4 wheel mounts fabricated and two welded on frame so far. Have to buy two rims for other tires before mounting them on frame, then finish painting lower frame. ;) :banana-dance:
100_1809_zps536bedd5 Welder cart wheel mounts fabrication.jpg (237.29 KiB) Viewed 15789 times
I am ordering two new tires with rims from ebay, Then get more welder cart finally rolling on some big tires. Made handle on front long tube with side handle to pull out around yard. :D
Working on welder cart, mounted up all four wheels. So now working on some cool storage box underneath for welding supplies. :D
100_1841_zps0468a62c welder cart.jpg (218.11 KiB) Viewed 15758 times
not your typical cart, I like that you can roll it over the ground easily.
