Busted Rubber - The Unwanted Child- Build
Next Chop
91 Ninja EX 500 R
91 Ninja EX 500 R
- jonester123
Re: Busted Rubber - The Unwanted Child- Build
Cool man, what you plan on doing to the motorcycle.
DIGGER!
or whatever happens!
Steel Frame
Steel Swingarm
75 horses
12 sec quarters
129 mile per hour top speed
0 to 60 3.8 sec
300$ and a chop no one else has! Watch this space!
10000 rpm revs before redline!!
Steel Swingarm
75 horses
12 sec quarters
0 to 60 3.8 sec
- jonester123
Sweet good luck on build.
Carbs not injection and chain drive + light weight. coils no fancy ingnition. Perfect for full frame build!
Concept drawing.
Next week on Jig
Next week on Jig
Broke her down a bit and removed wiring.
Then cut the tail section off.
I like the sound of this bike .
Sounds tough. Again you don't waste time.
Nice project, I'll be following closely.
Ready to alighn and weld down.
Frame gone.
Need to clean up neck.
Going to reuse these axle plates perfect to build off of.
I almost forgot I picked up the materials for frame build.
36 ft 1in dom tube .120 wall
8 ft 3/4 for slugs .120 wall
1in solid bar
3/4 in solid bar
1.25 solid bar
10 ft 1/2 solid bar.
150$
1in solid bar
3/4 in solid bar
1.25 solid bar
150$
Both rims are 16in.
Going to reuse both rims and if I do it right the axles as well.
The lower tree is steel so will be able to cut the steering shaft out and weld to new tree. Just do a build up technique for the girder trees with steel this time.
Still unsure about how far I can go on rake? 45, 50, 55, 60. degrees need to figure that out?
