gonna be a slow build
- sleepyonthree
Okay, put my thread back in so I'll have a pickup point when I get back to it.
- starting with the uncut donor axle
- uncut axle.JPG (75.32 KiB) Viewed 22677 times
- not the same axle but shows how much it was shortened 32 in back plate to back plate
- cut axle hsg.JPG (20.37 KiB) Viewed 22677 times
- cut axle bolted together for welding
- axle fixture.JPG (51.3 KiB) Viewed 22677 times
- electrolysis set up with laundry soda to help remove rust
- Laundry Soda barrell.JPG (135.03 KiB) Viewed 22677 times
- workin up the axle plates
- starting axle plates.JPG (124.55 KiB) Viewed 22677 times
- axles plate
- axle plate.JPG (120.88 KiB) Viewed 22677 times
- sleepyonthree
Re: gonna be a slow build
and a continuation.
- getting the tail frame put together
- started on tail.JPG (140.16 KiB) Viewed 22676 times
- made myself a purty neck fixture
- neck fixture.JPG (126.14 KiB) Viewed 22676 times
- getting the big chunks set in place
- gittin mocked up.JPG (82.39 KiB) Viewed 22676 times
- double cardan made from the cut down driveshaft
- double cardan.JPG (116.45 KiB) Viewed 22676 times
- fitting bottom rails
- starting bottom tubes.JPG (62.99 KiB) Viewed 22676 times
- bottom rails takin shape
- HPIM0652.JPG (77.46 KiB) Viewed 22676 times
- sleepyonthree
some more
- adding the top rails
- top rails.JPG (136.97 KiB) Viewed 22675 times
- makin the neck a bit more solid
- building up the neck.JPG (121.88 KiB) Viewed 22675 times
- some scraps to hold things in place
- wood jig for engine mounts.JPG (118.72 KiB) Viewed 22675 times
- using drill and flat file to turn down inner sleeves for motor mounts
- old fashined lathing.JPG (115.36 KiB) Viewed 22675 times
- engine mounts.JPG (134.44 KiB) Viewed 22675 times
- sleepyonthree
the donor motor. A 350 from and old camper. 1689xx mi on broken odometer. turned out to be a crate replacement with about 5000 mi on it.
- engine.jpg (72.13 KiB) Viewed 22674 times
- jonester123
Very cool and nice work there sleepyonthree. I have also been thinking about making a trike, i have a spare turbo 350 transmission in good shape plus rear end and a 350 engine to use. Engine needs a bit of rebuild but would be cool for a kick ass trike build. Time will tell
you know, i was wondering if you were making any progress on this. get on it man, this is an awesome project!
- jimmib
Thought for a minute you were building an Olds Trike with that Rocket valve cover. Good job.
Jim
Jim
- sleepyonthree
jimmib wrote:Thought for a minute you were building an Olds Trike with that Rocket valve cover. Good job.
Jim
Found them in my stash while rummaging about. Strongly considering making and adapter plate to use them on the chevy motor.
- jimmib
That would be a cool touch!
I still love the way you cleaned up the differential, way cool...
I asked you before about your plan to remove the motor ater the frame is complete, in case you needed to swap it out.
I think you said the plan was to just take it apart while in the frame.
Have you considered pinning the top backbone so it could be removed?
- sleepyonthree
The electrolysis bath sure makes for less time in the blast cabinent and it only does the rust, good metal remains untouched.railroad bob wrote:I still love the way you cleaned up the differential, way cool...
Had considered a removable backbone, but given the easy access to the motor I went all welded. The motor I'm using for mockup is a bare unit, once the real ones in place if I pull it out its to take it apart anyhoo so mights well do it from the outset.
- sleepyonthree
Whoops, to quick(spastic) on the keys.
hmmmmmmmmmmmmmmmm, very interesting......
now where can I find a large V8 and autobox......?
- sleepyonthree
Maz wrote:hmmmmmmmmmmmmmmmm, very interesting......now where can I find a large V8 and autobox......?
The Rover V8 makes for a good looking trike.
