Fractured Lacerations - Build - I Broke my Knife!
Re: Fractured Lacerations - Build - I Broke my Knife!
Turned my own nylon chain idler with proper bearings.
Made a braked stay bar.
Got the turn signals installed
Front brake spliter mounted.
Coils mounted.
Working towards the tank tunnel.
Ordered the brake stay parts today also. They will be here this week.
Coils mounted.
Got the tunnel done ready for tig welding.
Started layout on the brake stay bars also.
Working on mounting the tank and hiding the mounting bolts.
Got the front tank mount done and fitted the tunnel better for welding.
Made the rear mount sections to insert into the tank to hide the bolts there.
Rear tank mount is done.
- SELF INTRODUCTION: Howdy, I use to ride bikes and fix them, build them, cut them up and put them together again.
I dunno life comes along, promotions and longer hours at work kids .... then one day I wake up, and I just have to build another bike and start riding again.
I am looking for a site just like this to gain knowledge, look at the builds ...loving the way the board index is laid out. I have 90% of the tools I need, mill lathe etc... just need to refresh.
Dude I love the inspiration you have given me from not just this build, but your other builds also.
And your picture on face book with you and your daughter, it is precious and you need to get a hard copy of it before your computer crashes and you lose it. Hang it on the wall!
So I have not rode for almost 15 years, been a long time. I pulled my leather jacket out of the closet, and one thing from my old triumph is the leather saddle bags. Man the leather is dry, nice patina but needs work.
I started making my first part of my next bike, is the mirrors. Next will be the headlight and tail light.
I will follow some of the steps you used, and makes your posts with lots of pictures very helpful.
Keep it up and Thank You.
It is GOOD to see you here man!
These guys know more than me. If you need real knowledge the right people are here.
There will be no bullshit here either. Pictures of what you are doing maybe start a thread on it will help. Imgur.com is what I use for image hosting. Just click on large after uploading and copy paste in the text.
I have 250+ friend request now so, if you have tried to friend me hit me up with your name either here or in a Private message?
Front brake stay bars.
I'm surprised you did not make the stays " I beam " as well !
What a excellent way to use the heim's, they fit so well in the industrial look of the bike.
Glad to see others are out in the shop besides me, working off the turkey and pie
Nathan, I already have you on fb as Fred Larsen. I use my real name not the fool name.
And working on a introductory thread now.
Thanks Guys!
IRS fronts are known to sometimes flex the rockers with the suspensions independant from each other so, the heim joints were needed I thought so not to fight that action if it happens.
Modified the coil mounts and hid the horn under the tank.
Got the brake light switch mount made.
One handlebar grip done one to go..
Got the other grip done. Was asked in a couple places about the process so, took full picture set this grip. The throttle reuse the stock plastic liner pressed or glued in and the clutch side set screw.
1. Take solid stock of large enough size and drill and turn to largest diameter.
2. Turn any smaller sizes.
3. knurl.
4. Clean up edges of knurl by returning to them.
5. Bevel the edges with tool.
6. Use boring bar to machine to inner diameter needed.
7. Bevel inner edge.
8. Part the piece off.
9. Turn grip around and make shape or design wanted on outer part of it.
10. Drill and tap for set screw.
11. Install.
3. knurl.
11. Install.
Making some pod filters. Removed the rubbers from the stock air box.
They fit perfect in a 3 in exhaust pie with a swedge.
Made a brace and cut 4 pieces the same.
Welded a brace on them.
Not finished more to come but, forgot to buy bolts today.
