gonna be a slow build
- yona
Re: gonna be a slow build
Maz..... look at the Caddy Cetera....think there is a euro version...DOHC inline4 ( Half a Northstar )auto box , drive by wireless throtle, 4sp auto and a irs....with all suspension indy....mount solid and remove the tranny tail and cut down or use a 4x4 output shaft and make a plate for the rear seal. You can run the speedo off the front wheel. make your own a-arms for the rea,r to work with the stock uprights....mount a solo seat and run 2 small radiator in front of each a-arm or a one piece in the back...Gas tank out of a 10" piece of ally tube and mount a wing on top ....simple ally shroud to cover the trans, center section and radiator....this one might get built before my Northstar trike !
wow man that sounds like a recipe for a way cool trike.... guess I better get searching evilbay and the forsale adds......
now I'm spoilt for choice - inline 4 or rover v8.....whatever I find first guys
Thanks for the ideas guys
- yona
Some of those fours have turbo's .....stock probably puts outmore HP than a stock Rover 8.....!
- SELF INTRODUCTION: chewie from perth western australia. i'm triking up a vw and chopping up a yamaha and repairing broken tools. jeez 200 characters is a lot. GOT A WIFE AND KIDS SPENDING ALL MY PLAY MOEY ON FOOD AND CLOTHES AND OTHER USELESS SHIT sorry bout the caps put them on for the code thing
horse power schmorse power, nothin sounds like a V8
- yona
Ever heard a Ford flat-4 with a Reilly OHV conversion with a full race cam.... Sweet
ooooooooooooooooo you say the sweetest things you silver tongued devil you......
- SELF INTRODUCTION: Hi. I am LeeRoy, been biking for 30 yrs now. I ride an ironhead sportster, and (since I have a rider) am wanting to start a ground up build. I am really happy I found CBH, and want to thank you for info it contains. I look forward to the sportster hardtail article, and hope for a girder article
I love the way the world works. Maz is on the oother side of the pond, on the big v-8 hunt. I saw some pics of an Alfa-Romeo 75 based trike. The 2ltr twin cam version, (we called it the Milano here and only sent the v-6 versions). I would love to find some of the old european engines, from just about any manufacturer, to put in trikes. Some of them have so much going on visually I think they would be awesome. Oh well, dreams. I did find a pair of donor milanos close (by texas standards) so there may be a build list starting.
- sleepyonthree
- SELF INTRODUCTION: All around tinkerer. Hotrods, cycles, trikes, gardening, cooking, women. Originally joined CBH Jan 29, 2006. Way to many projects, but, thats the fun. Live out in the boonies, less complaints from conformist neighbors.
Picked up some rams horn exh manifolds from Speedway in their garage sale section. One was installed/returned, and the other had a generator mount hole offset drilled.
Cutting off the gen mounts anyhoo and the installed one looks like it was only opened. The garage sale discount covered the shipping difference.
Gettin closer to project restart....
- in the box
- HPIM0719.JPG (132.05 KiB) Viewed 10137 times
- buzz buzz
- HPIM0729.JPG (119.8 KiB) Viewed 10137 times
- needs finish contouring
- HPIM0726.JPG (117.95 KiB) Viewed 10137 times
- offset hole compare
- HPIM0728.JPG (104.42 KiB) Viewed 10137 times
- sleepyonthree
Whacked the offending portions, grinder to get the contour and casting lines/flash, 80 grit sander for cleanup and purtify.
Time to degrease then its off to the blast cabinet to return some of the cast look to the polished areas and a coat of Hi temp stainless header paint partially cured
at 500f in the shop oven for bout and hour. That should stop rust while they're on the shelf awaiting.
- HPIM0736.JPG (119.43 KiB) Viewed 10126 times
- HPIM0737.JPG (113.96 KiB) Viewed 10126 times
that sensor boss on the left side can be safely ground away you know !
- sleepyonthree
Unfortunately these are repops and the boss is hollow. Wanted too but would only end upgearhead1951 wrote:that sensor boss on the left side can be safely ground away you know !
with a big hole. Course ya only discover this once their in hand.
