In the midst of not so much chaos
Re: In the midst of not so much chaos
started on my tank...
- Split the seam
- 1.jpg (15.6 KiB) Viewed 5556 times
- centred the hole saw
- 2.jpg (13.19 KiB) Viewed 5556 times
- removed
- 3.jpg (11.1 KiB) Viewed 5556 times
only thing I noticed is to remove the bottom, before the fuel tunnel to keep the rigidity in the tank, less likley to make unwanted dents....The other thing I noticed, as theres a bit of chat about the sealer is, there was none..
This was a new Tank, abiet being in store for a while when you look through the fuel tunnel it looked like there was agood thick coating , but actually seen from the inside there is none, as you can see in the bottom pick. So I reckon save your money..
- Sum of all parts
- 4.jpg (13.05 KiB) Viewed 5556 times
- What sealer??
- 5.jpg (12.1 KiB) Viewed 5556 times
Bought a multi speed drill..lol......
You're REALLY chopping now...
Looks like your coming right along, Max!!!
Cant decide weather to slice out the middle or what?
Hi man, looking good so far. That gas tank is a mess, almost better to completely re design it. Cutt out all the bad areas and fabricate new.
Kiss my ass
are you going flat-bottom with that tank or just a small tunnel Max
Small tunnel...so it'll sit on the backbone..
That's what I thought....are you going to relocate the fuel pick-up point rearwards? It would increase the available fuel capacity quite a lot...an old problem on sporty tanks.....
heheh...happy a pig in sssssssssshit.....got all the bits for my lathe sorted, been having some fun, two chucks some tooling, and a bag of mixed assortment cut offs....maybe get some cones outa these.for my frame gig..
got some nice stainless for my exhaust tips and I picked up some old header pipes,,for normal rd use
You stepped in it now, Max. You know we're gonna need of your work.Maxthegardener wrote:.....got all the bits for my lathe sorted...
Hey that's great Max-man...now let's see some serious machining for that Buell of yours.....Maxthegardener wrote:heheh...happy a pig in sssssssssshit.....got all the bits for my lathe sorted, been having some fun, two chucks some tooling, and a bag of mixed assortment cut offs....maybe get some cones outa these.for my frame gig..
Me being a Pig in Shiiiiit... Having a bit of trouble with clutch slip...
- Me.jpg (19.01 KiB) Viewed 5458 times
