Lift table
Cycle-psycho
SELF INTRODUCTION: I've loved motorcycles all my life! I have a 2006 Dyna that ive been customizing and I am now taking on the task of building a custom chopper!
I have some mechanical skills, but im not a professional mechanic or welder. Simply a home garage type of mechanic.
Lift table
Post by Cycle-psycho »
Hey,
I am trying to build myself a lift table (see pic -its 9' long so I can fit my chopper on it!)) and I'm running into power issues with my cylinder. I am using a 3" bore - 14" stroke cylinder, but it doesn't seem to have the power to raise the table unless I help it up (which kind of isn't the point!). I have tried to remount it in several locations to improve the angle, but it wont work. I have a 60 gal compressor, so air power source isn't the issue. Could it be that the cylinder isn't big enough? and if so, how big of a cylinder would do it?
Cycle-psycho
2006 Dyna - with lots of goodies
2012 Ultima rigid - under construction
Re: Lift table
the cylinder on my lift is 5 inch diameter its a factory made lift it lifts heavy dressers the frameing on it looks very similar to yours not sure if it helps ya
Re: Lift table
You don't say what ram you have, except it is 3" with 14" stroke. Harbor freight has an 8 ton air over hydraulic ram and it will work your table with ease. They run less than $100.00. My tabe will lift an Ultra Glide converted to a trike with no problem using this ram.
Jim
monkeywrench202
SELF INTRODUCTION: I was a memeber on the old site, but couldnt log in here. I have a small shop where I do resto/ mods, build complete bikes (6 to date) ground ups. Been working @ Drive train specialists since 02 building custom automotive axles.
Re: Lift table
Post by monkeywrench202 »
60 gallon tank, but how much pressure? To gain more power, you either need bigger bore cylinder, or more pressure.
My lift is 5" air cylinder also. Shop air is 155 psi on low side - 175 psi on high end.
BIGJIM
Re: Lift table
Post by BIGJIM »
Air over hydraulics is the way to go.
