http://s528.photobucket.com/albums/dd32 ... plan-1.jpg
In this link the complete planes.
Hi people. I bring planes lift table. Very similar to maz miss, except that this does not have the same geometry. Front arms, where is the hydraulic jack, measuring 60 cms long, while the rear arms measured 70 cms. This allows the table to fold and bend forcing us to resolve a Rampla of only 10 cm high to raise the motorcycle. Disassemble hidraulic jack, so you can use it exclusively. The small front arm in arm fit the jack hidraulic head. To lengthen comfortably raise and lower arm raised, and put a spring under a pedal. Bleed valve is 40 cms long. so no stooping back hurts.
Testing the table in the backyard
All that is tilted.
Hope you like it. This design is working as multipurpose table in my shop cages for a long while, I've loaded with 500 Kg and the geometry does not allow the cylinder to deflate therefore needs no safety arms.
I use 5 mm steel pieces to make a U support for the arms, I did not think to use angle ... 3/8 bolts withstand without problems.
A hug!
