Thought I'd share how I made Cable ends for my Brake.I'll be doing the same for the Clutch.1st) was to make a little Solder Pot
- solder pot.JPG (123.17 KiB) Viewed 6221 times
...2nd) you'll need Flux for Stainless, got this at my Welding Supply
- flux.JPG (98.12 KiB) Viewed 6221 times
3rd)is to prep the Cable.I started by opening up the end with a small Nail.Just poke it into the Cable a bunch of times.This will allow the Flux into the Strands & give the Solder more to hold.This is unfortunatly the only Pic that I got.The 1st poke.But after it was done,I cut a small piece of the Nail & slide it through the Cable (it looked like the Pic)
- cable.JPG (94.85 KiB) Viewed 6221 times
.Let the Cable soak in the Flux for a couple Minutes.While it was soaking, I heated up the Pot with a Torch.Once hot start pushing Solder in.It should melt on contact.The way I did this was I dipped the Cable in the Solder just to Tin it.After it was Tinned, I took off the heat & started dipping again(it seems to get more Solder on the Cable as the Solder cools alittle).Continue till you get a nice little Glob on the end.Again forgot to take Pic.And now you can sand to the shape you need
- soldered.JPG (94.36 KiB) Viewed 6221 times
And here it is installed
- installed.JPG (118.73 KiB) Viewed 6221 times
I really pulled on this & it held.Hope someone finds this usefull.
