"A few drawings" If interested
Let's use this as an archive for whatever plans you have, or links to plans elsewhere. Before posting plans here, make sure you have permission to do so.
I have quite a few drawings that I have done over the years and will post them as I have time and energy.
Anyone is welcome to these files and do what you wish with them. Just don't try and flog them on Egay!
This first PDF may help some that don"t understand trail and raked trees. The drawing on left shows stock trees and the one on right shows 3 degree raked trees. The main thing to look at is the reduction of trail with raked trees. The height and fork length dims are ficticious.
RAKE AND TRAIL.pdf
(25.09 KiB) Downloaded 1678 times
This PDF is a drawing of a steering neck that you don't use cups with.
NECKNOCUPS.pdf
(22.62 KiB) Downloaded 1579 times
This next 2 PDF's are for you people that really want to say they did something. If you have the right equipment maybe so, but others should just buy one from JD2. They work with the JD2 model 3 bender. These were drawn up for for steel, but use your imagination :think:
1.25x4.5R DIE.pdf
(48.82 KiB) Downloaded 1724 times
1.25x4.5R follow bar.pdf
(16.95 KiB) Downloaded 1642 times
Re: "A few drawings" If interested
:text-goodpost: ill definatly useing some of those
Kiwicaveman
SELF INTRODUCTION: I am a mechanical engineer working in the oil and gas industry based in a gas treatment plant in south Taranaki new Zealand.
I live in New Plymouth, Taranaki, New Zealand
I have been riding bikes for over 40 years
Post by Kiwicaveman »
Thanks for the info
"This is your life, are you who you want to be?
This is your life, is it everything you dreamed that it would be
When the world was younger and you had everything to lose?"
Switchfoot
Theyr Iceland
SELF INTRODUCTION: Hi
im a marine engineer from iceland , im building 7 choppers from CBH softail plans.
For me and members of my club www.theyr.is , Im 42y and have been in bikes since 1989 and used to work as foreman at Kawasaki iceland workshop.
Been reading alot and following discussions on old forum .
i am a member there and although im not an active poster would like to
continue reading and learning.
Regards Gunnar Olafsson
Post by Theyr Iceland »
Thank you
Nice post, thanks for making them available
Here is another that I thought might interest someone. Oil Tank Plumbing.
BTW, most of my drawings have my company logo on them. I am not doing this for advertising. I haven't done any of this shit for several years and don't plan to (except for myself). Just trying to pass on a little info here and there.
So this is not spam!
Jim
OILTANK PLUMBING.pdf
(181.48 KiB) Downloaded 1483 times
Many thanks Jim..
And thanks from me too; I am grateful for the effort you make. Thank you.
Stuff I picked up over the years at CBH...
air planishing hammer.pdf
(56.53 KiB) Downloaded 1349 times
Pedal for Hammer.pdf
(188.43 KiB) Downloaded 1244 times
tube clamp plans.jpg (17.1 KiB) Viewed 22231 times
Return to “Downloadable plans Area”
