Death By SnuSnu's Vokaro
Use this area to post up any builds that aren’t bike related, but still probably interesting to the forum members. Use your own judgement on that.
DeathBySnuSnu
SELF INTRODUCTION: A backwoods redneck from way down south.
Re: Death By SnuSnu's Vokaro
Post by DeathBySnuSnu »
Fuel rails roughed out. Started on the finish machine work....but a ways to go yet.
And dug through the junk boxes and found a few parts to use.
Boards to build on and a pressure regulator and a map sensor.
DeathBySnuSnu
One intake built, welded and cleaned up.
The other parts made and yet to weld.
DeathBySnuSnu
The whittled flywheel, Mazda pressure plate, VW type 5 disc and throw out....... All fit into the Porsche 901 bell housing.
DeathBySnuSnu
Now to make an adapter to put the VW Jetta TDI starter on the Porsche 901 trans in the correct place to engage the VW type 1 ring gear.
DeathBySnuSnu
I did get a Jetta TDI starter adapted to the Porsche trans.
DeathBySnuSnu
Building chassis.....just the beginnings.
DeathBySnuSnu
Teaser mock up.
DeathBySnuSnu
Yeah.....still working on it....just no time.
I have done several small things.
Got a chevy distributor and made it fit.
Made a few mount tabs and what nots.
Painted a part or two.
Making pulleys...ect
DeathBySnuSnu
Painted valve covers..
DeathBySnuSnu
The big work such as the chassis is going slow. Just have not had the big time to spend on the big work.
I have about settled on where the body will sit and have started on the body mount perimeter.
DeathBySnuSnu
Modified a set of pedals.
One inch shorter and spread out.
DeathBySnuSnu
Well I don't post much..... not a lot of reply/questions here.....so I don't post often.
But.
I purdy much lost all of December being sick with covid.
Then spent all of January getting caught up.
Now just plain busy.
I am trying to get back on the project.....just so much job to do.
That means I have not had big time to do the big parts.
I have gotten some poly seats and established position and roll bar height. Then started bending tube. I had a chassis kit from years gone by....but it was not for this car
I have been blocking up the body and setting weights on it for 2 months now. I have evened out some twist and miss-shape and have the body sitting better. That also means I had to un-do some of my made to fit parts.
this is gonna be absolutely wicked when you're done. you gonna keep it pink?
DeathBySnuSnu
Actually that is the original color still on it.
When cleaned and buffed it looks like this .
But no..,.
I have tons of fiberglass work to do.
Just in my pics you can see I cut the tops out of the front wheel arches.....so I hafta bulge them out to fit.
Then I cut the whole back end off. As I lengthened the chassis I gotta create from scratch much of the back end. But I do have the valve covers below deck height....with the whole injection sticking out.
So..,I have a lot of body work and paint in my future.
I imagine silver and red like the old race porsches.
oh yeah, i can see that combo looking real sweet.
keep on keepin' on!
Return to “Non-bike related builds”
